Spraying on an LT1
Old Aug 7, 2007 | 05:19 PM
daniel6718's Avatar
i highly reccomend a mallory 685 for window switch/rev limitor/timing retard
Old Aug 7, 2007 | 05:26 PM
95camaroz28's Avatar
where do i get and how much and why so
Old Aug 7, 2007 | 09:30 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the TR6's are $1.99ea
see post #14 for my reccomendation for the budget you listed, it is an NX kit.
The Mallory 685 it is an aftermarket ignition control box. They are $244 and includes a single stage window switch and gives you the ability to retard timing if needed, if you are still on the stock tune you do not need to pull timing for the shot size you are wanting to run. I carry those as well.
Old Aug 8, 2007 | 05:16 AM
matt94z's Avatar
Ray is a sponsor on here. I'd recommend listening to him...http://www.nitrousoutlet.com/
Old Aug 8, 2007 | 06:48 AM
HOw hard is install on that
Old Aug 8, 2007 | 09:05 AM
WhyHelloOfficer's Avatar
A little bit of knowledge in wiring and electronics. It is a little involved taking the interior apart to wire everything and run the lines everywhere.
Definitely not unattainable.
Talk to Nitrous Outlet if you're concerned about the wiring part, they make super trick harnesses that are made to order, and literally plug and play.
Old Aug 9, 2007 | 11:53 AM
Well I wont be spaying all the time, I just need something to put the cap on things.....
I also plan on being sneaky with it.
Is pulling the timing necessary in my situation? I won't be spraying all the time once in a blue moon........
Can a vender here guide me to the basics?
Old Aug 9, 2007 | 02:54 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
https://ls1tech.com/forums/removed-locked-thread-graveyard/649117-nitrous-accessory-basics.html
If you have any questions please call and I will be happy to go over it with you.
 Michael S. Palmer
Old Aug 9, 2007 | 03:59 PM
jashell1562's Avatar
I have had 3 LT1 cars all with the spray with various mileage. Don't be nervous about the gas. use a wet kit and you will be fine. Its the retards that advance the crap out of their timing and still spary they cars and wonder why it broke that give nitous a bad name.
Old Aug 9, 2007 | 04:02 PM
TwoFast4Lv's Avatar
If your Budget allows it I would step up to the Nitro Dave LT1 Plate. Worth the extra IMHO. Listen to Ray he won't steer you wrong. Go witht he Autolite at .035 gap
BTW Spraying over 200RWHP out of the hole
Old Aug 9, 2007 | 06:35 PM
I want this to be sneaky so no plates!
Old Aug 9, 2007 | 07:02 PM
  #32
Ray@Nitrous Outlet
Guest
Posts: n/a
I can give you many suggestions on how to conceal the kit....
Old Aug 11, 2007 | 07:20 PM
  #33
camar0corey's Avatar
Bummer you don't want a plate, I'm looking at mine right now, and can't wait to get it in the car. Nitrous Outlet is the way to go.
