adding nitrous with a DS1C
Old Aug 6, 2007 | 09:19 PM
protwin's Avatar
Default adding nitrous with a DS1C
I have a lt1 383 w/ forged internals, trick flow twisted heads, matched ported intake, ds1c procharger 12.6 psi, With 60lbs injectors Comp Cam 233/239 cam – duration@.050” - .569/.577 lift Comp Cam Pro Mag 1.6 roller rockers/guide plates – non-self aligning
MSD blaster coil, MSD 8.5mm spark plug wires: tune was done by Dynolab.net and my numbers were 601.2 rwhp & 564.8 tq @ 6100 rpm How much nos can i run without running race gas and how do i apply.
Old Aug 7, 2007 | 09:54 AM
Matt@HSW's Avatar
How is the fuel pump system set up?
Matt
Old Aug 9, 2007 | 07:39 AM
protwin's Avatar
I have two walbro 255 pumps and not also bought a better fuel mangment system so my fuel presure in the rails would be more constant.
Old Aug 9, 2007 | 07:43 AM
BLNLS1/RX7's Avatar
You need to speak with Bob at EEP. They installed a 300 shot on my camaro with 794 RWHP and 849 TORQUE results.
Old Aug 9, 2007 | 08:36 AM
SPLATT's Avatar
jesus BLNLS1 awesome numbers!! You too protwin.
Old Aug 12, 2007 | 09:26 PM
LSTBRED's Avatar
This is prob a rook statement but I thought it wasn't a good idea to do both together, unless it's a small "cooling" shot? Please let me know either way, that way I'll know/learn. Thanks
