is this fuel feed line too long?
Old Aug 10, 2007 | 09:36 PM
ls2 bait's Avatar
Default is this fuel feed line too long?
its the one that came with the kit. id assume its ok if it ame with it but someone told me it was too long and could cause a lean spike so i figured id ask.
Old Aug 10, 2007 | 11:19 PM
sworaz's Avatar
Wow, that intake is sweet!
Old Aug 10, 2007 | 11:36 PM
98Camarod's Avatar
I dont see how, as long as your fuel pump is up to the task you should be fine. The fuel will be constantly there waiting to be used.
Old Aug 11, 2007 | 12:00 AM
Tally TransAm's Avatar
as long as the lines from the solenoid to the plate are the same you should be fine
