biggest and best nitrous cam for A4
Old May 25, 2003 | 11:24 PM
BIG PD's Avatar
Default biggest and best nitrous cam for A4
k i'm setting my car up to have a 150 shot on it after heads and cam. i'll have S2 5.3 heads with 11:1 compression. i need to know a good nitrous cam that is fairly large so it will do well when the nitrous isn't engaged. thanks for the help.
Old May 27, 2003 | 07:04 AM
Smoke T/A's Avatar
Default Re: biggest and best nitrous cam for A4
How bout the F1 cam. 230/226 .591/.569 112 I ran 7.6@92 N/A with the cam and stock heads. Went 6.5@109 on a 150 shot. I belive the people who make this cam have a shop car that runs High 7's NA and high 5's on the juice in the 1/8th. LMK I have the cam for sale also if you are interested asking $350 for it.
Joe
Old May 27, 2003 | 08:15 AM
BIG PD's Avatar
what about a trade for my T1 and 50 bucks from me?
Old May 27, 2003 | 09:08 AM
Smoke T/A's Avatar
Sorry man I already replaced it with a solid roller. But thanks for the offer. LMK if you want it.
Joe
Old May 27, 2003 | 12:27 PM
Chris Spiess's Avatar
As a general rule, N2O will like more exhaust (duration and lift) and wider LSAs. However, if you're not builidng the motor for dedicated N2O use, then get a good N/A cam to benefit the most wide range of driving and just spray it
Old May 27, 2003 | 12:30 PM
CAT3's Avatar
Restricted User
Ditto!
Old Jun 4, 2003 | 09:10 AM
needmoremoney's Avatar
I built my setup like this for my TNT kit: The cam is a custom Comp grind (228/236 .571.602 111LSA) Heads are SII RMS 5.3's 2.02/1.57, double springed. ARP head STUDS, and all the other bolt-ons. As you can see, I think the nitrous will love my cam choice.
Old Jun 4, 2003 | 12:40 PM
C4VetteLS1's Avatar
Thunder racing did me a custom n20 grind that works well on motor.
Its a 227/230 and it made 413 on motor with heads/cam combo. and its great for large doses of nitrous
Old Jun 4, 2003 | 09:14 PM
BigPlanTransAm's Avatar
needmoremoney: are you an M6 or A4 if your an A4 your trans aint gonna like that 111 lsa and i woudl think the nitrous would like a little wider lobe seperation as well
Old Jun 9, 2003 | 07:43 PM
Yes I am an A4 (FLP level IV) and the car idles @ 900RPM's fine since i drilled the T.B to 3/16.
Old Jun 13, 2003 | 10:01 AM
beardWS6's Avatar
I like the X1 cam from MTI on 112 lobe. I`m tuned safely for the spray and still pulled good N/A numbers, check sig with what I have. When I sprayed She really got going. This cam sounds awsome! PM me your E-mail address and I can send you my dyno sheet on spray and bottle. MTI picked my cam! Jayson tuned it.
Old Jun 13, 2003 | 12:24 PM
ls1290's Avatar
Dumb Ass Vette Moderator
The Grand Am Cup cam on a lsa of 112 would be awesome: 239/251//570/570
Old Jun 16, 2003 | 10:16 PM
TApimp's Avatar
How bout the F1 cam. 230/226 .591/.569 112 I ran <a href="mailto:7.6@92">7.6@92</a> N/A with the cam and stock heads. Went <a href="mailto:6.5@109">7.6@92">7.6@92</a> N/A with the cam and stock heads. Went <a href="mailto:6.5@109</a> on a 150 shot. I belive the people who make this cam have a shop car that runs High 7's NA and high 5's on the juice in the 1/8th. LMK I have the cam for sale also if you are interested asking $350 for it.
Joe
that would be speedtek, we havent gotten the car into the 5's yet but it will be very soon, we are having some tuning probs with the new setup.
our old setup went a best of 6.4 @ 109 f1 cam, speedtek heads, NX dual maf kit 300, full stock weight, along with full wolfe suspension, and almost no ls1 edit tuning.
car made 680 rwhp/ 870rwtq also had out built tranny.
i have our SPI1 cam in my car only made 367 on the motor,
on 100 shot it made 488/ 512 on the 150 shot it made 537/668 those were both 10.0 a/f, so i have a little tuning to do that was through an a4 unlocked. motor has 128k miles on it.
817 282 0042 call me at the shop if you need anything else
craig
