nitrous system suggestions??
Old Aug 22, 2007 | 02:21 AM
99LS1zul8r's Avatar
Default nitrous system suggestions??
any suggestions on what nitrous system i should go with on my 99 z28
Old Aug 22, 2007 | 02:31 AM
JustAnIlluzion's Avatar
they are all the same, most of the components are made by peter paul
Old Aug 22, 2007 | 03:20 AM
95 Z28's Avatar
I'll be the first to ask...what are your goals for the car, and what is your current setup? I got all the info I needed from the "wet vs. dry" thread. Search for that and read away.
Old Aug 22, 2007 | 07:28 AM
01Z28M6's Avatar
If you do the research you can buy the components and build what you want. That way you'll have the right length hoses etc..
If I had it to do over again I would have bought an extra foot on the hose for my nitrous feed as that sometimes helps avoid an initial lean spike. Most kits will have equal length hoses (wet kit) that are usually longer than what you need - for example.
Find a nitrous parts dealer and work with to get exactly what you want for looks as well as function. You don't have to use one dealer for everything either. Just an opinion. Good luck.
Old Aug 22, 2007 | 07:48 AM
Patrick G's Avatar
LS1 Tech Administrator
Moved from Internal Section.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 22, 2007 | 01:18 PM
Chris@NitroDaves
Guest
Posts: n/a
There are two basic kinds of systems. Wet and dry. Both have their pros and cons. Did you have a preference in mind? Also what mods have you done/ plan to do?
-Chris
Old Aug 22, 2007 | 02:04 PM
99LS1zul8r's Avatar
i only have exhaust right now but i'm about to order slp cold air,ls6 intake,and still trying to decide on a cam and headers
