How much spray on a walbro 255
Old Aug 24, 2007 | 09:14 PM
dnkynrbk's Avatar
Default How much spray on a walbro 255
What is the max shot you can do on a walbro 255 intank and what option do you have if you want to spray a 250 shot or 300 besides going to a standalone fuel cell. any options as far a s intank pumps or putting a dual set up in your tanks. please post pics if you have them to.
thanks
Old Aug 24, 2007 | 09:54 PM
383LQ4SS's Avatar
SIngle 255 walbro and volt blaster from Speed Inc I have done 700+ rwhp (T56) on about 4-5 setups. Thats TOTAL hp. Wether you get 400 all motor and 300 shot...or 500 all motor and 200 shot etc etc.
Some of those where with dry setups and 42 lb injectors and some where with wet setups and some where a combo of both in two stages.
Old Aug 25, 2007 | 03:53 PM
skinnies's Avatar
With the boost a pump, I know some guys on cz28 have made 700rwhp also with 6 speeds.
Honestly, just do a fuel cell, put good gas in it, and be done with it!
Old Aug 27, 2007 | 09:32 AM
Chris@NitroDaves
Guest
Posts: n/a
Typically we have seen about 500-550rwhp out of just a 255 pump only. With the hot wire kit included with the pump we have seen around the 650-670rwhp mark.
-Chris
Old Aug 27, 2007 | 08:26 PM
dnkynrbk's Avatar
What would be your choice then to run a my walbro 255 and which pump. or just buy a stand alone
Old Aug 28, 2007 | 09:06 AM
Chris@NitroDaves
Guest
Posts: n/a
If you are good on fueling right now on motor ( As the car sits ) then i would suggest going to a dedicated IMO. I would get the racetronix Hot wire harness and put the pump in the car so that way you know you are 100% covered on motor since you already have it and then get the didicated so you are 100% covered on the spray.
-Chris
