n2o trouble
Old Aug 24, 2007 | 10:41 PM
itsslow98's Avatar
Default n2o trouble
need some help. i have a tnt power ring setup and i just had an ls6 intake installed. ever since the install i cant get the nitrous to spray. i have checked all the fittings and switches and WOT switch but cant figure it out. Any ideas? anything can help. thanks
Old Aug 25, 2007 | 07:23 AM
Ms Eliz's Avatar
Sounds frustrating! I been through a couple difficult times in tracking down issues so I feel your pain!
First and formost I would look at ground (-) locations, you said you checked switches which is a good idea but I'm assuming their locations and terminals would not have been touched just because of an intake swap. What could have changes though are the items removed from your set up during disassembly and reassembly of the intake. Look in that area and pay particular attention to ground wire locations and any wire connections in general surrounding the solenoids.
Hope this helps!
Ms Eliz
Old Aug 25, 2007 | 07:36 AM
purdueranger's Avatar
Did you use one spot for all the ground wires or did you spread them out a little bit?
What all did you disconnect to install your LS6 intake?
Old Aug 25, 2007 | 11:15 PM
itsslow98's Avatar
I bought the car with the nitrous already installed so im not sure how the install went and i just paid a guy like 75 bucks to install the intake instead of bothering with it. Ill check the grounds tomorrrow when its not downpouring. thanks for the input.
Old Aug 27, 2007 | 08:54 AM
thislswon's Avatar
if the wires are ran through the boot on the passenger side door they mightve got cut in half from the door closed on them...happened once to me when i had my z28
