Calling Dry Nitrous Master Robert 56
I am taking a guess here as to why the solenoids are mounted near the nozzle instead of where the bottle is placed.
With solenoid closer to nozzles, less distance for the nitrous to travel when activated. Remember, there is nitrous in the line up to the solenoid.
From what i have read, most are placing the nozzle 2-3 inches away from the MAF. Perhaps 5 is too far and thus the bad reading.
Second there isn't nitrous in the line up to the solenoid if you don't purge (although I bet it is pretty damn close...14.7 psi air vs 950 psi N2O)
I think your guess is on the right track though where the phase change from liquid to gaseous N2O occurs in the line when the noids are close to the bottle.
No the remote valve will not change the maff reading. Yes it will alter the flow of the nitrous and more than likely cause a phase change but you should never see any differences in what the maff is reading.
You can not put the solenoid at the back of the car even though its just a dry shot because the system would see a huge delay in when the nitrous hits and shuts off the flow.
Dave
You know you can get phase change with the pick up tube in most bottles. just flairing the end of the tube will stop this. but the point is, at our levels phase change is really not a great concern.
As has been said, noids at the bottle aren't good because your long line will be empty. But something you can do, and I have done this. with your noids close to the motor, you can increase your line length leaving the noid, and create a softer hit, or a poor mans delay/ws. I posted a dyno sheet of this and the hp and tq curves mimick a turbo's curves allmost perfectly.
Robert
Dave
Robert
Dave
