Solenoids too big!??
Old Aug 30, 2007 | 06:15 PM
Charles Cyrus's Avatar
Default Solenoids too big!??
I'm looking at getting a good deal on a pair of NX solenoids out of a Pro Shark kit. The nitrous one is rated at 500hp and the fuel has a .187 orifice. I going to be using them for no less than 200-shot no more then 300. The question is, Would these be too-much?
Thanks
Old Aug 31, 2007 | 09:22 AM
Chris@NitroDaves
Guest
Posts: n/a
The super shark is way overkill for less than 200hp shot but will work for what you are wanting to use it for. You probably will need to check your AFR ( air fuel ratio ) cause the original jetting may vary a little with that big a noid.
-Chris
Old Aug 31, 2007 | 09:49 AM
SMITH's Avatar
why you lying? you know you gonna end up with a lot more than that.
Old Aug 31, 2007 | 10:35 AM
I hope to, by the end of next year.
