looking for the 250shot .. ??? experts help !!
tsp 2.5 5.3l heads milled
ms4 cam
arp head studs
cometics head gaskets
eagle h beam rods with arp 2000 bolts
diamond piston and full seal rings
stock crank
fast 90/90
Electric waterpump
long tune 1 7/8 headers
fuel :stock inj and 255lph in tank pump ...but will be upgrading inj soon .. how much bigger ??
nitrous kit ... nitrous outlets total packege 90 plate kit ..
im looking for a 250rwhp shot ... of course with a great tune and 116 race gas with the juice
im thinking of running the full 250shot with a progressive controller trough the 90mm plate..
or would it be better for a 150 plate and 100 dry ?
ill have all the safety products WOT switch and window switch... a wideband Af gauge botle heater blowdown ect ect...
any ideas on how much power with the juice ? torque?
what else do i need to complete my goals ? what am i missing ? anything to knw before everthings done !?!?
also were could i pick up a good progressive controller? i was thinking of nitrous outlets progressive controller... any of u running this controller ?
well engines almost fully asembeld and im getting the rest of the parts ima need to get it done just need some imput from u nitrous gurus...
thanks for the help in advance guys
Should get you there so long as you're under about 440rwhp with the cam/heads. You could consider just buying a standalone system, but the idea for the pump/injectors may still be a need with that heads/cam setup you have going there.
If you're looking at the setup you have, Im going to estimate between 440-460 n/a rwhp, and about 700 if you go for a full 250rwhp shot overall. Thats a lot of horsepower, I hope you realize that.
any advantages of 100 dry 150 wet over the progressive 250 shot ?
look at going with a dual intank setup on a wot/hobbs switch. so that you can run 1 pump if you just drive around and then the second pump will activate under heavy load.
another option is an inline pump. they will ultimatley hold more power.
good luck.
