MSD Timing Controller
Old May 30, 2003 | 02:06 PM
JurisAg02's Avatar
Default MSD Timing Controller
I am looking into buying one of these. I have seen them on numerous Turbo/Supercharged apps. They basically allow you to adjust the timing from inside the car to adjust for boost, altitude, bad gas etc etc. I was thinking this would also be beneficial for a motor wanting to spray a large shot but still run great NA without it always running crappy because of a lack in timing. I wanna be able to run optimal timing NA then crank it down ALOT for the "little" shot of juice I have. I was wondering if any of you had any experience with it for this use and what your opinions were. Any of you have access to one for sale? They are kinda pricy new so I might wanna shave some of the cost off of it by going used.
thanks in advance,
Rick
Old May 30, 2003 | 06:03 PM
383LQ4SS's Avatar
Default Re: MSD Timing Controller
It would be ideal...however MSD currently does not make anything compatable with our LS1 ignition system
Ramcharegers>>>>
Now they have a Timing Tuner which can be used for LS1s and has a few more features too. Do a search for Timing Tuner and also check out the link for Ramchargers on the right>>>>
