wot switch placement
Old Sep 9, 2007 | 05:02 PM
onoiocoko's Avatar
Default wot switch placement
i've been lookin at pictures of people mounting their kits in the engin bay. i havent see the wot switch. mine is right near were the cable goes to pull the throttle body blade. im installing the kit right now and am having trouble getting the switch to mount with out letting the movable part of the throttle body from locking on the wot switch and the wot switch getting stuck open being too close to the throttle body. anyone have any pictures of their wot swiches in the bay to see if mines in the right spot? thanks.
Old Sep 9, 2007 | 05:11 PM
JEB99TA's Avatar
Not sure how they do it, but, a lot of folks mount it right under the accelerator, even though I think most manufacturers tell you to do it where you're mounting yours. I guess it all depends where you are tapping in for your switched 12v hot lead. I'd like to see some pics, as well.
Old Sep 13, 2007 | 08:14 PM
JEB99TA's Avatar
I'd ike to see some pics as well ... anybody got any?
Old Sep 13, 2007 | 10:39 PM
daniel6718's Avatar
under peatl its easy..use one of the column bolts and let the petal bar hit the wot switch
Old Sep 13, 2007 | 11:36 PM
TwistedSS's Avatar
Check out the instructions for the NOS 05177 dry kit on Holley's website.
Old Sep 14, 2007 | 05:04 AM
Danger731's Avatar
I'd rather the engine bay
Attached Thumbnails wot switch placement-1-qtr-07-156.jpg   wot switch placement-1-qtr-07-159.jpg   wot switch placement-1-qtr-07-160.jpg   wot switch placement-1-qtr-07-165.jpg
Old Sep 14, 2007 | 05:08 AM
Danger731's Avatar
link:
http://www.harrisspeedworks.com/shop...cat=322&page=1
Old Sep 14, 2007 | 07:31 AM
jmill96Z's Avatar
I've got a HSW kit, and I moved mine to the gas pedal. Pretty simple setup.
Old Sep 14, 2007 | 12:24 PM
onoiocoko's Avatar
that forth pic helps. mine is between the trottle cable "C" and the throttle body instead of there. thatt might help
