tach output wire?
You running the two stage Trick Engineering Window Switch (Dynotune/Nitrous Outlet)?
From the PCM I believe it you set it for four cylinder mode. You can check whether its right or wrong by holding the first button down, it will show you what its reading
Above showing idle at 700 RPM
