which tps wire for nd window switch?
Old Sep 13, 2007 | 11:01 PM
ls2 bait's Avatar
Default which tps wire for nd window switch?
which one do i want to tap into at the pcm for the 2 stage window switch/ tps module?
pin 24 (red connector) tp sensor signal or
pin 8 ( blue connector) tp sensor 5v ref ?
Old Sep 13, 2007 | 11:27 PM
BayAreaSS's Avatar
You want to tap into pin 24 on the red connector. Its a dark blue wire.
Old Sep 14, 2007 | 12:14 AM
ls2 bait's Avatar
cool. thats the one i used. but i was looking thru my diagram and saw the other and second guessed myself. i know it said it needs 9v min to work properly so i figured it was the blue conn anyways.
