how much can I spray on 28degrees timing?
Old Sep 15, 2007 | 08:47 PM
matthewjosh's Avatar
Default how much can I spray on 28degrees timing?
I have a walboro 255 and I'll be running around 107 octane!! So far I've only sprayed a 100 shot but I'm going to the track and thinking about a 125 or 150 my other mods are in my sig. what do u guys think with 28 degrees tim....
Old Sep 15, 2007 | 09:35 PM
any body?
Old Sep 15, 2007 | 09:37 PM
jmill96Z's Avatar
I only sprayed a 100 shot. Once I stepped up a little I pulled the timing
Old Sep 15, 2007 | 09:46 PM
What was your timing at when you pulled it? How much did u pull?
Old Sep 16, 2007 | 08:47 AM
anybody? Going to the track in a couple of hours!!
Old Sep 16, 2007 | 08:59 AM
02SOMWS6's Avatar
spray a 75 shot to be safe for now. That was all I sprayed for my 10.6 & 10.7 passes. Oh, I didn't see you were spraying more. Stick with what you have sprayed before and get yourself a timing tuner so you can adjust it easier
Old Sep 16, 2007 | 09:29 AM
GrannySShifting's Avatar
none, if you like your parts. Be smart and tune it right, and safely!
Old Sep 16, 2007 | 09:50 AM
THEBRAD's Avatar
i sprayed 125 with 30 degrees on 108 leaded race gas
Old Sep 16, 2007 | 01:20 PM
jmill96Z's Avatar
Once I started spraying a 150 I pulled it down to 23-24 degrees.
Old Sep 16, 2007 | 05:33 PM
i sprayed a 125 no problems thanks guys. I ran a 7.19 spinning on a 100 shot uped it to 125 and ran a 7.38 spinning more.
Old Sep 16, 2007 | 07:24 PM
BayAreaSS's Avatar
i have 28 degrees of timing and i havent sprayed it because i dont have a tune. i just dont want to kill my motor because i didn't wait for a tune
