Simple Question
Old Sep 18, 2007 | 02:08 PM
taillights's Avatar
Default Simple Question
How much is safe to spray with TNT Power ring if I steal the fuel from the stock rails,pump Etc. All stock fuel system Thanks.
Old Sep 18, 2007 | 02:28 PM
Ego Killer's Avatar
I did a 100 shot on mine never had a problem off the rail..put you a walbro 255 and I sprayed 200 never a problem
Old Sep 18, 2007 | 03:20 PM
taillights's Avatar
I've heard 150 from alot of people but will probably step up later anyway. Thanks for the input.
Old Sep 19, 2007 | 10:02 AM
Chris@NitroDaves
Guest
Posts: n/a
Depending on your mods you can get away with a 100shot and even a 150 shot if the car has no internal motor mods. If you have a cam i'd definitely get it on a dyno to check AFR ( Air Fuel Ratio ) cause the stock pump supports around the 450rwhp range.
-Chris
Old Sep 19, 2007 | 11:29 AM
taillights's Avatar
Thanks this is a modified motor I'm sure the pump will need an upgrade before the spray it's making almost 450 now Thanks for the info.
