Universal Wot Switch Mounting Bracket
Old Sep 18, 2007 | 08:20 PM
1998Z20what?'s Avatar
Default Universal Wot Switch Mounting Bracket
Is Anyone On Here Using The Universal Wot Switch Bracket They Give You With Harris Speedworks Or Nitrous Outlet Kits? Its For A 1998 Z28 Ls1.. And No Matter How Hard I Try I Cant Figure Out How The Hell To Get It Right...also, I Have The Stock Accordian Style Bellow ( Between The Maf And The Throttle Body) And That Is Where I Put My Nozzle, Is It True That I Have To Switch To The Smooth Bellow To Make The Nozzle Work Right? Or Can It Be Done Throught The Stock Bellow? Help And Pics Would Be Greatly Appreciated.
Also If Anyone Has Any Specs On A Custom Made Wot Switch Please Let Me Know. I Seen The 30 Dollar Mounts By Jimmy Jams, But I Dont Feel Like I Should Spend 30 Dollars For A $0.50 Peice Of Metal.
Old Sep 19, 2007 | 10:09 AM
Chris@NitroDaves
Guest
Posts: n/a
Default Sorry I don't have any pics of the setup
When i first had a kit on my car about 7yr's ago I used the standard WOT switch . I went off the bottom bolt on the TB for the mounting point and bent the bracket that was supplied. You will need to adjust the metal toggle coming out of the wot switch to fit your application. It's a little harder to install but you can use the nozzle with stock style bellows but isn't recommended. We do offer a custom wot switch/bracket http://www.nitrousoutlet.com/catalog...product_id=821
-Chris
Old Sep 19, 2007 | 11:09 AM
jmill96Z's Avatar
I tried to figure that thing out too. I ended up just putting it under the gas pedal.
Old Sep 19, 2007 | 10:19 PM
MyTA99's Avatar
Click the link in my Sig. I have good pics showing this.
