First test of the nitrous and I ran into a problem..
Old Sep 18, 2007 | 08:21 PM
12secLS1's Avatar
Default First test of the nitrous and I ran into a problem..
I installed a 125hp jet for the first test and it looked like it was going to work. The first run I brought it up to 3K rpm in 2nd gear and hit it. It blew away the tires right away so I let off. Then I took it up to 3K rpm in 3rd and tried it again. This time was awesome, tons of torque and it seemed to run real smooth.
Now the problem. When I was coming back, I did the same run in 3rd gear and it seemed to surge real bad. 3-4K rpm it pulled real hard, then it died off, then it seemed to kick in again at about 5K rpm.
To give you more details about my setup: Single nozzle and I rotated the MAF clockwise so it would hit the wires better. Any problem with doing that?
What do you think is wrong?
Old Sep 18, 2007 | 09:22 PM
SchultzLT1's Avatar
MAY have something to do with the MAF. The best advice I can give is check the bottle pressure, and if you feel yourself losing that kick let off the nitrous.... There is a chance your MAF isn't see'in the nitrous and it is dumping lean into your motor.
Sorry, wish I could help more
Old Sep 18, 2007 | 10:04 PM
GregWS6&z28's Avatar
assume it's a dry shot?
Old Sep 18, 2007 | 10:06 PM
12secLS1's Avatar
Yes, a ZEX dry shot.
Bottle was full and heater had been on for a while.
Old Sep 18, 2007 | 11:20 PM
12secLS1's Avatar
Anyone have any ideas?
Old Sep 19, 2007 | 12:33 AM
99DWPTA's Avatar
isnt a 125 shot of dry a little big far a stock tune... or is it tuned???
Old Sep 19, 2007 | 08:34 AM
SchultzLT1's Avatar
personally, anything over 100 I would go wet. I'm content with my Dry 100 though.
Go out and try it again, it may have been a one time thing, or take the nozzle out, shoot it into the air, and make sure your getting a steady shot out of it
and do you have a 99 or 00? Those only have little baby 26# injectors.
Old Sep 19, 2007 | 08:38 AM
860 Performance's Avatar
I know you said the bottle was full, but weight it again just to be sure. It sounds like low-bottle-surging.
Old Sep 19, 2007 | 10:40 AM
12secLS1's Avatar
I had the bottle filled right before I installed it and it weighs a lot more than it was when it was empty so I don't think there is a problem there. And I checked for leaks but I teflon taped all the connections so nothing was leaking out.
The car was tuned (it's an '01) and the timing is retarted 4 degrees. It has all bolt ons but heads, w/ stock internals. Should I be aiming the nozzle at the 2 MAF wires on one side, or in the middle of all 3 of them? The nozzle is pretty close to the MAF.
Old Sep 19, 2007 | 11:00 AM
HPT BANDIT's Avatar
whats your a/f with the dry shot?
Old Sep 19, 2007 | 11:02 AM
Bird_Of_Prey's Avatar
Move the nozzle back from the MAF. You will have freezing problems if its too close. I've frozen the MAF on my V6 before. It was a pretty similar experiance to what you have described.
Old Sep 19, 2007 | 12:04 PM
12secLS1's Avatar
Haven't had the A/F checked with the nitrous yet, just finished installing it yesterday. What's the easiest/cheapest way to get it checked? Put it on a dyno?
Old Sep 19, 2007 | 04:18 PM
12secLS1's Avatar
Finally some good news: I tried it a few times today and it worked great. Maybe the computer just had to get used to it or something because it really hauls *** now. 11s here I come
Old Sep 19, 2007 | 04:22 PM
Ponch's Avatar
so what is your A/F ratio?
Old Sep 19, 2007 | 04:27 PM
12secLS1's Avatar
Old Sep 19, 2007 | 04:44 PM
Ping King's Avatar
bottle may have been full but what was your bottle pressure?
Old Sep 19, 2007 | 04:56 PM
12secLS1's Avatar
I don't know, I don't have a guage. But the heater had been on for ~25mins before I used it and it was hot. But it works now so all is good.
Old Sep 19, 2007 | 08:03 PM
HPT BANDIT's Avatar
You could go to a dyno with a wideband and have it done but I would just buy a wideband. Not knowing what your A/F is is just asking for trouble. I wouldn't spray anymore untill you get it checked.
Old Sep 19, 2007 | 08:39 PM
12secLS1's Avatar
Roger that, thanks guys for all the advice.
