Tips on NOS tuning w/150+ shot
My AFR is low 12's what i remember, ill prly drop to high 11's for a 200 shot.
Any more tips?
I am running NGK TR-6's.
I dont know my comp ratio as i bout the engine as is...i think its 11.1:1.
Thanks in advance.
Oh...I have a NOS progressive controller as well.
There are lots of LT1/LS1 engines out there making over 600hp on the back end. (like mine)
Just run it a little fat, use all the fail safes, and have a bullet proof fuel system and I think you'll have no issues.
Change your fuel filter more often too.
Good luck, sounds cool!
better back way off the timing and save it for special occasions till you can forge it. use someones handheld tuner to drop a several degrees AND MAKE SURE YOU USE RACE GAS 104 or better
225 is pushing it especially with the cam etc, and stick with the 150 and maybe up it once in a blue moon when you know you have time to fix whatever gets burnt.
