2 stage plumbing question
Old Sep 28, 2007 | 09:42 AM
slowprocess's Avatar
Default 2 stage plumbing question
Ok, I've got most of the parts needed for my two stage setup(both wet). Currently I have the basic nozzle setup with noids(my 50shot off the line due to traction problems) and the NOS brand plate system with the NOS super pro noids(150shot). I'm running the -6AN feed line. I'm basically just trying to figure out the plumbing now. I guess I need a t fitting from the feed line to the two nitrous noids(need to know what fitting to purchase), as well as a t fitting that will split the fuel to each noid. If someone could give me the correct sizes(or better yet part numbers) on the t-fittings, I will be more than greatful.
Old Sep 28, 2007 | 02:48 PM
As always thanks for the quick replies I think I'll just take my kit off of the car and install it on the truck for the first stage........Now all I need is a t fitting for the fuel rail and I'll be set. I'll be able to keep nitrous pressure alot higher and more consistent running the two seperate bottles anyway.
Old Sep 28, 2007 | 10:01 PM
Robert56's Avatar
hmmmm... Maybe some of us have lives, lol? Anyway, better than a "T" is to run a "Y". You'll have a little better flow and much tricker looking. You can see what I mean in pic, between bottles.
Robert
Old Sep 29, 2007 | 08:10 AM
Damn, I do like the way that looks alot better......let me look one of those up. Thanks for the heads up.
Old Sep 29, 2007 | 08:48 AM
Beer99C5's Avatar
Matt at HSW has a build your own Y fitting on his online store. Give him a call if your not sure if you need 1/8" NPT, -4AN or whatever...
