Plate question
I just stuck in the 62/33 jets I was using with the Shark Nozzle. Am I ok? Anyone think I am going to see any actual improvement?
On my stock car the recommended jetting was a bit rich and we went with two jets smaller on the fuel. Once we added a H/C package the recommended jetting was lean. If your modded, I would say your at a good starting point. Of course its recommended you check your AFR and adjust as needed.
I've got a cam, but stock heads. The majority of the mods are in my signature. The important ones are Torquer V.3, SVO30#, Hotwired Walbro intank fuel pump.
"Of course its recommended you check your AFR and adjust as needed."
I was afraid of that. I was hoping someone would say, "ah, don't worry about it. It's FINE!"
