FJO Gauge Compatibility??
Old Oct 1, 2007 | 01:14 AM
Jeff@TotalPerformanceEng's Avatar
Default FJO Gauge Compatibility??
Hey guys,
Does anyone know wether or not you can use any other gauge with the FJO stuff?? What I mean is, is I have the FJO wideband and Nitrous pressure system on its way. The problem is, is the gauges are the WORST I have ever seen. Their so cheasy looking its ridiculous. They look like a cheap ebay gauge.
So I was hoping that I could use the features of the W/B and N2o pressure, but use just a basic gauge like the dynotune version.
Old Oct 2, 2007 | 05:09 AM
Good God Man.....
Someone has to have tried to use a different gauge with the FJO stuff..
Old Oct 2, 2007 | 06:31 AM
gi8e7oi825's Avatar
I use my AutoMeter A/F gauge with FJO's analogue out. I don't see the actual AFR number, but I see the pretty lights! So you can do it. As far as the nitrous gauge is concerned... I'm not sure what their nitrous pressure system is, but if it uses the same digital pressure sensor that the AutoMeter elec. nitrous gauge uses, then you should be able to tap into the same wires. I hope this helps, but if you have any more specific questions ask, and I'll do my best to answer them.
Old Oct 2, 2007 | 07:52 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
have you tried to power up the gauges. They work well, and are really easy to see in the daytime.
