is it save for me to use 150 shot?
Old Oct 2, 2007 | 07:15 AM
Thule's Avatar
Default is it save for me to use 150 shot?
i am purchasing my nitro kit from nitrous outlet,
90mm plate system,
i got a h/c/i motor, comps 11.1,
the pistons/crank are oem, but thats about it, got performance bearings, katech headstuds, katech rod bolts, ported ls6 oil pump, ls2 time gear and chain, clevite perfect circle rings and more,
is it save for me to shot 150? or should a just go 100?
Old Oct 2, 2007 | 07:36 AM
njc.corp's Avatar
i think u are in the wrong section-try the n20 section-but since u are here from my use with n20 i have and still spraying 175 with factory stuff apart from 36 pounds injectors-mild heads 224/228 @50 112- fast intake and holley 90 ml
no rod bolts,no forgies and standard comp ratio- i have laid down 540-560 rwhp with 4 degrees taken out @ 175 worth of spray- so i dont know if u will need to take timing out or not on your comp-maybe not has the hit u indicate is only 150-
no et has i have not race it yet-
try the n20 forum as their is some switch on people their-why don't u even ask nito daves as they are very very switch on and have a very good customer service-
hope that helps u a bit-
Old Oct 2, 2007 | 09:12 AM
Thule's Avatar
thanks.. i was goin to put this in to the nitrous forum.. and thougt i did :S
Old Oct 2, 2007 | 09:42 AM
TN94Z's Avatar
Stock is supposed to be good to 150 but with the other mods I would say maybe a fuel pump and injectors to be on the safe side. On my stock bolt on 98 I ran 150 consistently and a few 200 hits with no problems.
Old Oct 2, 2007 | 12:20 PM
Thule's Avatar
i got an racetronix fuel pump kit W/voltage booster, and 36lb's injectors,
Fast 90/90 and fast fuel rails
Old Oct 2, 2007 | 12:23 PM
TN94Z's Avatar
I guess reading you sig would have helped.....I would think you would be okay then.
