Stock v6 plus NOS
Old Oct 3, 2007 | 08:59 PM
BlkBird2000's Avatar
Default Stock v6 plus NOS
I don't know if you guys know much about v6's and nos together... but i have a 3.8 v6 firebird that's in the best condition ever! I wanna use a 50-75 shot. Will that be okay or too much? Is it okay to use nos on a stock motor? Also i was looking at some nos and saw dry nitrous. Is there a difference between regular nitrous and dry nitrous? Thanks for you help!
Old Oct 3, 2007 | 09:14 PM
Oso SS's Avatar
I think I sprayed a 100 shot on my 2000 V6 camaro and it worked fine. Might've been a 75 shot but either way it worked great.
Waxed a 03pi motor swapped 96 GT with it too
Completely woke the car up and gave it a little bit of *****. Make sure you put plugs in that ************ though! Swapping plugs in them is SO easy too, makes me miss my V6... only when I'm swapping plugs though, I'll stick with the LS1 otherwise.
But yeah I think they're completely good up to like 100hp worth of spray. I think I would put a bit of 100 or 109 in it just to be safe though. I can't remember for **** what I did.
Old Oct 3, 2007 | 09:33 PM
Should i use dry or wet spray?
Old Oct 3, 2007 | 09:47 PM
95 Z28's Avatar
Dry, but I'm biased ... do a search for "wet vs dry" that thread gave me all the info i needed to make my decision on which kit and whether to go wet of dry. The Nitrous FAQ and Accessory Basics threads stickied at the top of the nitrous forum are also a **** load of help.
Old Oct 5, 2007 | 04:50 PM
Oso SS's Avatar
I used wet.
Old Oct 7, 2007 | 08:25 PM
donkey mule's Avatar
I would use a 75 wet kit but start at a 50 shot 1st and monitor it.
