who makes a good dry kit?
I bought a Dynotune Dry kit, and expieremented with Dry Nozzles (Dynotune, HSW and NX). The nozzle I eventually settled on was the NX Dry nozzle. Two reasons, one the NX nozzle is larger than the others (1/8 NPT vice the 1/16 NPT) and the NX nozzle is machined with the NX logo on the spray side of the nozzle so its easy to figure out where the nozzle is pointed (when changing jets, you may mess up the orientation) without filing the nozzle with a notch or marking it with a perm marker.
BTW heres my Dynotune thread.
https://ls1tech.com/forums/nitrous-oxide/777856-dynotune-dry-kit-way-write-up-soon-follow.html
Feedback is welcomed.
After decideing if wet or dry best fit your set up and abilities I suggest comparing the components in the systems to determain what is best for you.
If I can help in any way let me know.. Ohh there is also a post around here somewhere explaining the things to look at when comparing nitrous systems..
Dave
Robert
I've heard great things about Nitrous Outlet, that's probably where I'm gonna get my kit. Make sure you get a fuel pressure safety switch and installing a window switch so you can program start and stop RPM is a good idea too.
http://www.nitrousoutlet.com/
Dynotune would be my next choice. They also offer some really good products & both compaines have great customer service over the phone & on this board.
