Solenoid Mounting Help
Old Oct 10, 2007 | 01:37 PM
DopeFedZ's Avatar
Default Solenoid Mounting Help
I'm starting on the second stage (dry kit) and was wondering if the solenoids being mounted on the head is a good location. I plan on running a -4an line from the solenoid to a Y fitting underneath the Volant intake then two -3an lines to two dry nozzles. Should I be worried about the distance the nitrous is traveling due to the length of the lines? I will only be spraying a 50 maybe 75 shot on the dry kit.
Old Oct 10, 2007 | 02:00 PM
Ego Killer's Avatar
that short of a distance will not IMO be a problem.
Old Oct 10, 2007 | 04:32 PM
Derek @ EDO's Avatar
should be fine
Old Oct 10, 2007 | 07:38 PM
socmguy's Avatar
Restricted User
DAMN! you got a good looking setup!!!
Old Oct 10, 2007 | 10:14 PM
Robert56's Avatar
really the only role line lenght plays with a dry hit is it can act as a poor mans WS if longer. Or, it can hit a little softer when long, wouldn't worry about your lenght though.
Robert
