Maximizer II data log output
Old Oct 10, 2007 | 09:30 PM
captainwizbang's Avatar
Default Maximizer II data log output
While I was tinkering with the MX2 I notice that the log data is VERY rough. I was hoping it was just the real time monitor that was a little flaky, but... For example, while idling, I could have RPM spikes up to 9000. Needless to say I'm scratching my head. I've included a snapshot of me in neutral just running the RPM up slowly from 1000 to 5500. I think you can see what I mean. Is this normal?? If so, how does the system compensate for the RPM spikes an not shut off the nitrous prematurely?
I guessing that maybe the ground isn't good since I'm getting spikes on all inputs including the WBAFR. What do you think?
Old Oct 10, 2007 | 11:28 PM
96silverram's Avatar
I agree there is something not quite right. If you have that much resolution within the graph it should be more smooth.
Old Oct 11, 2007 | 12:43 PM
I'm going to try changing the ground this evening. I'm currently using the factory ground that sits just below the fuse box on the dirvers side dash. I'm going to create a dedicated ground point and connect it to that. Maybe i'll get lucky.
Old Oct 11, 2007 | 08:17 PM
New graph attached from post rework on the ground. I took if off of the common and created a dedicated ground. Much cleaner but the FJO AFR is still very dirty. I dont know if this is normal or not. I woudn't think so.
Old Oct 12, 2007 | 11:59 PM
Dedicating a ground point was a step in the right direction. I'm wondering if you can do a hard reset to the FJO device and correct what seems to be a resolution mapping problem. It seems like it is working okay, but I agree that the signal looks very dirty (sketchy).
