Running a BMN Window switch???
Old Oct 19, 2007 | 05:51 PM
MadMike329's Avatar
Default Running a BMN Window switch???
What do you guys think about this window switch and who is using it. i'm pretty sure it's not a digital cause you set the RPM window with dials. what i thought was odd is that you have to run a WOT switch along with this window switch. what i know is that it is "microprocessor controlled" and has a first gear lock out. i ask cause i haven't really seen anyone on here using it. is it a good switch? are the digitals really that much better? i bought this one from HSW along with my dry kit and a purge kit and they recommended it so i took their word.
Old Oct 19, 2007 | 05:57 PM
~RedLineLs1~'s Avatar
I've been running the BMN unit for awhile and I'm happy with it. it does it's job and hasn't skipped a beat. The customer service at BMN is also top notch. Bill is an awesome guy to deal with.
Old Oct 19, 2007 | 09:41 PM
MadMike329's Avatar
right on man, thanks for the reply! i'm planning on setting it up tomorrow so i'll post the results.
