window switch setting?
Old Oct 20, 2007 | 08:53 PM
grn95t/a's Avatar
Default window switch setting?
when should i shut the nitrous off? have an a4. command to start the shift is set at 5800 rpm's and shift end is 6200 rpm's. was going with 5700 rpm's as suggested by tuner,but wanted to ask some experienced nitrous guys!
Old Oct 21, 2007 | 04:29 PM
grn95t/a's Avatar
no one?
Old Oct 21, 2007 | 06:47 PM
00formLs1's Avatar
so you start at 5800?
i go 3000 to 6100.
Old Oct 21, 2007 | 07:04 PM
grn95t/a's Avatar
5800 is where the pcm commands the tranny to start shifting. what rpm does yours end the shift at? cause i belive that i should be set like yours is. when i hit the traps at the end of the track i am pushing 6000
Old Oct 21, 2007 | 07:52 PM
00formLs1's Avatar
my first is commanded at 5800 but shifts like at 6000, the rest are 6150 but shift at 6200.
so i spray through the shift in first.
Old Oct 21, 2007 | 08:04 PM
grn95t/a's Avatar
cool thanks for the info!
