Harlan 2-step/tbrake/nitrous help needed!
12V Ign directly to the tbrake solenoid
ground to the momentary button on the shifter than to the tbrake solenoid .the brake works great .
i tapped the white wire on the harlan 2 step between the button and solenoid to give it a momentary gorund while holding the tbrake button.
I can get it to work but i have to tap the momentary 1 time to arm the 2 step. than hold it the 2nd time the 2 step works and will release when i let go of the momentary the 2nd time.
The problem is my tbrake botton has to be pressed for reverse to work on my glide. so its turning the 2 step on and off as i use reverse. I could wire a toggle switch in it so the 2 step is not in the circuit until turned on but thats just 1 more thing to remember at the line. i like to keep it simple. is there a way to wire it so the arm and on function works with only 1 push of the momentary? I dont want to have to doubel press it. And a revlimiter in reverse woun't hurt me so this would be ideal.
I tried putting the gray and the white togeather to both get the momentary ground and also giving the gray an all-time ground. neither worked.
2nd question. I have never used the 2 step. how acurate are they at stoping the revs? I want to start with it set at 3K and have the nitrous come on almost imediate. I could wire another relay so it will send 12V to my FJO so the nitrous will not be on on the brake but i have enough electrical **** i don't want any more. so what is the fluctuation on these boxes? will 200 rpm be enough of a window to keep it off on the brake?
I tried asking in the external section but noene likes to reply in there. I figured this would be the best place for a reply.
as for timing. i ran my 2 step at 3k with a 10th delay in the timmer and never had an issue, so im guessing in 1 tenth after my brake was reliesed im sure it was around 200-300 rpm so im going to say you should be fine with that. just dont turn it to low i did have a back fire leaving at 3k no delay.
my computer is under the dash and not 1 wire from the 2 step runs under the hood. its very nice.
