deactivate nitrous when 2 step is armed?
Old Oct 22, 2007 | 10:16 AM
ls2 bait's Avatar
Default deactivate nitrous when 2 step is armed?
is there a way to do it? basicly off clutch activation. i want to be able to use my 2 step and have the nitrous come on as soon as i release the clutch. the way its wired now i will have to do first gear lockout on my window switch and consider the car on the line with the 2 step activated as first gear.
Old Oct 22, 2007 | 10:34 AM
ShiznityZ28's Avatar
Which 2 step?Which controller? Does it need a 12V or Ground to disable the nitrous?
Old Oct 22, 2007 | 10:40 AM
ls2 bait's Avatar
probably useful info huh. its a synergy 2 step and nitrous daves controller. here is my wire diagram.
Old Oct 22, 2007 | 10:47 AM
WickEdSix98's Avatar
Do you have a NX instruction booklet? If so, use the trans-brake diagram but connect the clutch engage wire where the trans-brake wire would go. You will need another relay but its pretty easy to hook up.
Old Oct 22, 2007 | 11:14 AM
ls2 bait's Avatar
i have the nitrous outlet booklet. doesnt seem to have a tbrake outlet?
Old Oct 22, 2007 | 12:42 PM
BadAssFast's Avatar
It seems to me you can always have a relay open the n20 ign B+ circuit as necessary when TB button in depressed and reclose when it's relased to refeed B+ to N20??
Old Oct 24, 2007 | 10:04 PM
ls2 bait's Avatar
t.t.t.
