Suggestions/Advice Needed--- Single 300 Plate + 100 second stage
Old Oct 26, 2007 | 08:28 AM
WizeAss's Avatar
Default Suggestions/Advice Needed--- Single 300 Plate + 100 second stage
Went to the track this past week.... ran 10 nitrous passes on a progressive controller. The car ran a 6.48, 6.53, some 6.6's etc... I needed a bottle warmer and pressure guage.... I also didnt want to go without a delay out of the hole. used a 1 second delay and 85% on my best pass.....with low bottle pressure.
I decided to ditch the controller and do the 300 out the hole. The car leaves straight and easy (weak nitrous converter).
I am going to put the TB WOT switch on the Gemini plate with a 300...... I also have a button on my shifter.... should I put the 100 on the button? How safe is this? What spark plugs are needed for this setup?
I hotlapped my car on the 200shot plus... it never got hot (gotta love Iron Blocks!)
details on setup: 3850#, 408, Diamond Pistons, TH400, GMPP Carb Style with Elbow, TR6 plugs.
Right now I only have 2 selenoids and a purge.... the biggest honkers you can get, good for 600 worth of spray.
Old Oct 26, 2007 | 10:47 AM
Nitro Dave's Nitrous Outlet's Avatar
You should be fine doing that. I would just make sure bothe stages are on a window switch for safety. I would also run the 100 shot stage on a wot switch in conjuction with the button. This way even if you push the button it will make sure you are at wot.
Dave
Old Oct 26, 2007 | 01:11 PM
WizeAss's Avatar
Dave
Good advice.... I have a WS on the car, but it wont work with my setup so I hear.
will these plugs work fine vs my TR6's?: NGK R5671A-8
can you identify which one it is? I dont remember... it is on the glove box:
Old Oct 26, 2007 | 01:23 PM
TARZAN's Avatar
I'd run TR8's myself....also, have you considered putting the 2nd stage on a delay?
-Will
Old Oct 26, 2007 | 01:30 PM
WizeAss's Avatar
-Will
IMO the button will act as the delay... I will hit it just a bit before the 2nd gear shift.... or after....
with the converter and gears it will be very safe to spray after the shift.. and if it is only 75/100 it wont do anything to make the car react funny down the track.
I also can use the smaller shot on the button on the street for fun..... spraying the 300 all the time will cost alot of money... only 3 passes a bottle!
Old Oct 26, 2007 | 01:43 PM
TARZAN's Avatar
If its only 100 more....any chance it'll take both, out the gate?
-Will
Old Oct 26, 2007 | 03:24 PM
WizeAss's Avatar
-Will
nope... i am too chicken!
