Dual Stage dry kit
Old Oct 29, 2007 | 11:29 PM
chrismorales75's Avatar
Default Dual Stage dry kit
What jetting/ shot would you recommend for a 1998 ls1, stock motor with a 255lph fuel pump on pump gas.
I would like to run two stages.
Old Oct 30, 2007 | 09:01 AM
Chris@NitroDaves
Guest
Posts: n/a
Wiht you havinng the stock motor i wouldn't suggest you go over a 150hp shot. There are people that are spraying more than that on the stock motors but keep in mind that at any time it could go BOOM!! 2 stage dry jetting would be
.031 + .031 = 70hp
.035 + .035 = 100hp
.041 + .041 = 150hp
-Chris
Old Oct 30, 2007 | 11:22 AM
[QUOTE=Chris@NitroDaves;8034925]Wiht you havinng the stock motor i wouldn't suggest you go over a 150hp shot. There are people that are spraying more than that on the stock motors but keep in mind that at any time it could go BOOM!! 2 stage dry jetting would be
.031 + .031 = 70hp
.035 + .035 = 100hp
.041 + .041 = 150hp
Is the .041 jet a 75 hp single jet power rating? I will be using a single nozzle and will just use the fuel side for n20. So I think I will go with 125.
Would that be a single .041 and .035 jet to = 125?
Would just like to double check it.
