Black Series Display Controllers INSTOCK!
Old Nov 13, 2007 | 02:21 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
Originally Posted by Beer99C5
I am at the back, trying to figure out my heater scheme...even though the gauge has the built in heater controls, the pressure gauge is on the mainline in my configuration, so I have to have the bottle open for the gauge to correctly control it...however, I think I will just connect the heater wire from the gauge to the relay, like it was from a switch (and the heater pressure switch on the bottle will work as it should). The gauge will auto shut it off after 15 minutes (with the bottle closed) because it will not see a change in pressure; if the bottle gets to pressure before the 15 minutes the bottle heater switch will shut it off. I can live with that and just be aware of it.
Beer that wire from the guage is a ground wire NOT hot. Recheck your layout.
Besides your not suppose to heat a bottle closed.
Old Nov 13, 2007 | 02:55 PM
Beer99C5's Avatar
Good catch! I am on it! Nuthin been powered up yet (battery is out of car).
Called Vinny and he set me straight...once I got the heater set up I will power it up. The * connection is 12 V Switched and the heater is controlled by the gauge through the ground (git it now!).
LC-1 stuff I will do tommorrow.
Old Nov 14, 2007 | 09:04 AM
black01_WS6's Avatar
what guage did you end up going with?
take some pics of the different screen shots if you could.
Old Nov 14, 2007 | 12:52 PM
Beer99C5's Avatar
Went with the V, its the one that is not a progressive controller.
I am close to powering it up, LOL I have been busy cleaning up the old wiring...what a mess it was. Much Cleaner now. Figuring out my power source then will connect and hopefully it will work!
Jim
Old Nov 14, 2007 | 01:20 PM
Beer99C5's Avatar
Powered it up, have not programed the inputs yet. Looks Great!
Old Nov 14, 2007 | 01:48 PM
NXRICKY's Avatar
Beer if you see the hour glass do not shut the gauge off, its saving data to memory. Looks good.
Old Nov 15, 2007 | 06:28 AM
Well it didn't take too long for you to hook it up. Looks good.
How bright is it at nighttime?
Old Nov 15, 2007 | 07:17 AM
Beer99C5's Avatar
I will have more pics later, todays agenda is to program the LC-1 Analog1 volts to 10 and 20 AFR, finalize the power and grounds to my panel and the gauge, and tap into the Pressure sending unit wire to log bottle pressure.
May even do a lil video of the gauge booting up, I am told it can be programed to boot up with with custom pics or logo's (have to send it to Trick Performance for that).
Old Nov 15, 2007 | 08:24 AM
A custom logo would be pretty trick.
So are you using the entire lc1 or just the wideband itself? I would assume you are using the entire unit, and running a wire from the lc1 unit to the guage.
Old Nov 15, 2007 | 09:02 AM
Beer99C5's Avatar
I am using the entire LC-1, both analog outputs. Analog 2 goes to the EFI Live Scan Tool, Analog 1 will fed the guage. The Dynotune gauge (removed and will probably put in my Avalanche) has different parameters than the Black gauge, so its a matter of changing the analog 1 outputs to match the black gauge... I also moved the LC-1 Cal button I had rigged in the battery tray into the cab and to my panel. Just finished that. Early afternoon I hopefully will be done and snap pics of the various menu's and correct function of the heater pressure/AFR readings.
Old Nov 15, 2007 | 09:11 AM
after doing all of the work would you reccomend getting a lc-1- as it is the best wideband out right now, or somehting else.
I am going to be buying everything by the end of next week, and just want to make sure I am getting what I need and not wasting money.
Old Nov 15, 2007 | 04:00 PM
  #32
Beer99C5's Avatar
Up and running
Now to get pics
Above Heater on
Above heater off
Pretty neat ****!
Have a video selecting screens and turning on the heater. Its 19 megs though...maybe reshoot it in daylight and edit for web use.
Very cool combination! Everything works Bottle Pressure, heater, LC-1 WB
The color of the text for each sensor is selectable, I used green for 950 PSI and up, as you can see the bottle text is red because its not in my selected window.
For nite time use, you can dim the gauge one step darker than the bright setup.
Going to get with Vinny in Dec for setting up the safety's and bottle Full/Empty settings.
Old Nov 15, 2007 | 05:08 PM
  #33
very trick, glad its up and running.
Old Nov 16, 2007 | 09:40 AM
  #34
NXRICKY's Avatar
Bump for the cool clean factor.
Way to go Beer. very nice install.
Old Dec 27, 2007 | 01:33 PM
  #35
Aaron92SE's Avatar
Bump!
Does anybody have the P gauge yet?
And thanks for the pics Beer.
Old Sep 9, 2008 | 06:40 PM
  #36
LS2Greg's Avatar
I have the P gauge, but will be taking it to a shop to have it installed. I set aside time last weekend, but pinched a nerve in my neck and was stuck on the couch all weekend...SOOOO yeah...have to have a shop do it now since I'm crunched for time.
Does ANYONE have a DIY guide for the install?!??
Old Sep 9, 2008 | 07:09 PM
  #37
Speed Density's Avatar
hashtagBMW
These gauges are the most bad *** peice on my car. The V-Gauge is so sick to watch do its job!
