Made a few passes with my new setup!
Old Oct 31, 2007 | 08:56 PM
BAKED's Avatar
Default Made a few passes with my new setup!
I finally got to take my new setup to the track on Sunday.
The car was blowing through the converter pretty bad so the MPH was nowhere near what it should be but I was still happy for the first time out with a medium size shot.
Here's the specs on the car
99 Z28
Stock cube LS1
Diomond Pistons (10.97:1)
Eagle Rods W/ARP2000 bolts
Comp Cam 234/242 .598 .608 113
Absolute speed stage 2.5
LS6 intake Shaner S2 TB
Stock crank
Stock water pump
Powerglide W/ brake
Edge Pro 3800
Moser 9" W/ 3.55's
325-50-15 Mickey Thompson Radials
BMR Suspension
Around 3000 lbs race weight
2 Stages of juice, 100 wet and 100 dry
My best pass was:
1.45 60'
6.21 @ 112
9.77 @ 135
That pass was off the trans brake, the next pass I flashed it from about 2500 and cut a 1.37 60' but I was a little greedy with the timing and melted the TR6's. I think with a tighter converter and a set of colder plugs I can get low 9's on a 300-350 shot. I guess we will see come spring time!
Old Oct 31, 2007 | 09:06 PM
98REDZ's Avatar
wow that is kickass! I have a very similar setup myself, other than I lack the heads just yet,...and haven't gotten around to the spray either til i switch some other things, but plan on running a 3.55 gear, who knows what tranny, and still thinkin about weight reduction although i dont know that i'll end up doin it. Thats crazy its 3000lb raceweight
Old Nov 1, 2007 | 08:02 PM
BAKED's Avatar
Thanks, I'm not 100% positive that it's 3000 lbs, it may be a little heavier than that but it's had alot of **** taken out of it.
Old Nov 1, 2007 | 08:29 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's nice for a 200 shot 347.
