When To Spray An M6?
Old Nov 3, 2007 | 02:31 PM
Zero4488's Avatar
Restricted User
Default When To Spray An M6?
I've been reading alot of threads about not spraying below 3000rpm or above 5500rpm.....but those have all be for A4's....I was wondering what guidelines I should use for an M6 with a WOT and a FPSS. Also If I should get a window switch as well....I'm getting everything ready before I hit the button and I just wanna make sure I don't do anything stupid a end up walking around.....
Old Nov 3, 2007 | 03:25 PM
purdueranger's Avatar
never go below 3k in any vehicle and letting off where you shift at.
Old Nov 3, 2007 | 03:51 PM
Sunset'01Z's Avatar
get a window switch too. it will engage the nitrous for you in a certain rpm range. say 3000-6000.
Old Nov 3, 2007 | 04:34 PM
BLAKE 01 WS6's Avatar
imo a window switch is a must w/m6. mine is set on-3500 off-6500 limiter set at 6800. you do not want to hit the rev limiter on spray. along with a wot switch
Old Nov 3, 2007 | 04:53 PM
99FRC's Avatar
Definitely get a window switch! Nitrous Outlet has a good one with WOT switch built in. Mine's on at 3000, off at 6000 and rev limited at 6500.
99 FRC
Old Nov 3, 2007 | 11:37 PM
98TADRIVER's Avatar
3000-6000rpm here as well on my M6. my rev limiter is set to 6400rpm. I have a WOT switch and msd digital window switch.
