need help..Just got off the dyno... Not good.
Pulled 3 degrees of timing and went
410 & 390....
On the 100nx wet shot, using 52/31 jets...
It stumbled and bogged after 4200.
It looked ok from 2800 - 4000
Torque went to 525 almost right away, but HP NEVER went above 420... Then it dropped off above 4200..
Torque fell off after 4200-- big time as well...
It was serging like crazy.
I don't have a fuel pressure gauge yet. I also DO NOT have an external pump, but the Injector pulse rates looks great.
ANY idea on what the *(!#@ is going on??
Why would torque jump and the hp didn't.
Air fuel was 11.8 until 4200.. ?????
Did you run an A-tap at the time of Dyno?
It never went lean at 4200?
It really sounds like you ran out of "gas". I assume you have not up graded your fuel pump in any way. I'd upgrade the fuel system, and/or run an Atap at the time of the dyno run.
David
It was at 12.0 from 2.5 to 4.2 rpm. Then it jumped to 13+ when it surged and sputtered and fell off badly.
Didn't see any knock retard though.
I'm running tr6's at .038.
Sounds like I might need an inline pump. T-rex maybe...
Fuel is safety on spray, it`s like insurance!
