9.08 @ 148.... 3700lbs! ... Video.
looks good tho, if the car is in one piece i dont know how you can sleep at night without that 8 sec slip. you are right there!!
get that thing to another track and give it hell, you know it will do it
haha ......That should help it not wheelie right?
We are going to get it up on my lift tonite and see whats up with it for sure.
I may take it to the track on Sunday if we can get it fixed.
We need to tighten up the limiters some more
i put mine as low as i could without hitting my lift lol the rest is history.
I made some bump stops on the shocks to stop the front from bottoming, that plus heavier front springs and raising the front up some = 1.25 60 foots with no limiters and 6" wheelstands. I use the two step to adjust my wheelies, 3500rpm equals bumper drag, 2700rpm equals a nice peaceful ride.
timming out of the hole also helped me, i kicked 2 degrees to 6k rpm and it helped HUGE!!
I'm leaving off the foot brake. 1500rpms.
Noyzee, we are going to tighten up the limiters and shocks if that doenst work I'll try taking some timing out.
Thanks guys!
I use a 300lb QA1generation F spring right now. It really calmed the car down a bunch and I dont scrape the headers on the brakes anymore stopping which is nice.
Just takes some experimenting..
it went right up to the moon i thoght i was screwed, i let out just to let the spray off and i think because the car makes steam on motor, it kept the front up and helped it from slamming down. (still touched the headers and front ground fx) but then i put the 2 step up 500 rpm and gave the converter less flash and it hit hard, went a 1.30 60 on the rear tires but i still had to let out for a split second.
pulled 2* and boom, it hit the tire mint carried a good 50 feet and sat down mint.
it takes a while, once you find a good tune up, then just work on suspention and you will pick up tons.
car is very impressive for sure!!!
Nitrous is a little touchy with bottle pressure, purging, timers etc but once it all works together a good leaving nitrous car is pretty awesome. One thing for sure about nitrous, supercharger, NA or turbo 4th gens, doing wheelstands is a problem and not a good thing
