FPSS/window switch
Old Nov 23, 2007 | 02:51 PM
supersickss's Avatar
Default FPSS/window switch
Was jsut wondering if anyone has previousely looked and knew were i could get a FPSS and a window switch for a reasonable price. ive looked at switches but the cheapest ive found is $99 i wasnt sure if thats a good price or not. and am also wondering if i even need a fpss, im only spraying a 100 shot max prob 75 on a all stock motor, with a dry kit.
Old Nov 23, 2007 | 04:51 PM
Mike@HSW's Avatar
http://www.harrisspeedworks.com/shop...cat=308&page=1
Here is a link to our Window Switch, its a little bit over a hundred bucks but definitly worth it. It has additional features like first gear lockout and built in shift light output. Give us a call and we can work you through any other technical questions you have.
Old Nov 24, 2007 | 09:02 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
Dynotune FPSS:
http://www.dynotunenitrous.com/store...?idproduct=135
At Dynotune we test and calibrate your FPSS before it ships no need to set it.
Our window switch:
Capability for 2 stages, built in electronic TPS (Much cleaner install - no need for a WOT switch) , multi gear lockout feature, ability to activate the nitrous in whatever gear you choose, Push-button programming with integrated LED digital display and Compact rugged, waterproof design.
http://www.dynotunenitrous.com/store...?idproduct=194
Dean
Old Nov 24, 2007 | 11:59 PM
Nitro Dave's Nitrous Outlet's Avatar
Dont let price being your deciding factor on the window switch. The style windowswitch dean has listed above is the best on the market abd well work the extra 29.00/ Look at the features it offers. It is also completely sealed and you canm mount in anywhere.
We carry the same thing with our name on it as well so that should tell you it must be the best on the market.
Dave
