fuel rail test port question
Old Nov 24, 2007 | 10:58 AM
Ruckus46Gt's Avatar
Default fuel rail test port question
Finishing up the install on my friends trans am and just have to hook up the fuel side now. Question we ran into do you just take off the shrader valve and put the fpss and line to the noid on or is there an piece that goes in there so you dont have to pull the valve( i know my nx kit for my stang had a fitting that went in there and basically pushed the valve down so it was open)
Old Nov 24, 2007 | 01:12 PM
bombloader's Avatar
Yup, you must remove the valve and then put the fpss on.
Huh, small world, I work at the MOC.
Old Nov 24, 2007 | 06:21 PM
Blindmelon's Avatar
The best set-up I have seen is the new NX before the fuel rail set-up that just came out. It goes in-line where the fuel line goes to the fuel rail. It has 2 ports you can tap (one for nitrous & one for a gauge) or you have a plug to plug one. It just takes a fuel line removal tool to install. This way you aren't pulling off a rail but before the rail. For about $50.00 it is a sweet way to go.
Old Nov 24, 2007 | 09:08 PM
2002t/a06's Avatar
yea well we removed the valve and were screwing the fpss on and the tip of the ****** fuel rail broke off. no i gotta get a new fuel rail . ( this is on my pos car btw)
should have stayed with just a dry shot!!
Old Nov 24, 2007 | 09:38 PM
Bullitt4110's Avatar
That sucks, those things are pretty fragile.
Old Nov 24, 2007 | 11:05 PM
2002t/a06's Avatar
hell yea. ****** thin *** copper.
