Trying to setup for big numbers low ets have ???
spraying a plate on a vic jr what is the general induction setup used?
elbow and tb or carb style tb( what throtle cable bracket is used)\
any troubles with anyone about intake leaks on the victor jr. if so how to fix thanks for any help
jeff
You can run a throttle body Bolted down just like a carb. The most common is to use a elbow with the throttle body. We custom build elbows that simply just bolt down. You will not have to trim the cowl and everything just plugs in. Including Evap.
We can plumb spray bars into the intake and it saves hood clearence. I have a set up sitting on the shelf complete with intake,elbow, and spray bars. Ready to ship.
Dave
