This might be a stupid question.........
Old Nov 26, 2007 | 12:17 AM
02' hawk's Avatar
Default This might be a stupid question.........
I was thinking about putting 2 NOS bottles in my car and was wondering if it would be worth the extra cost? The reason for doing so is: The 1 bottle does not last long; Also when i purge it seems to act right but when i run down the track it wants to surge like it's picking up some air from the bottle. The reason i think that is because i took the old 15lb. bottle from my old kit with the high flow valve and put it into my new 10lb. bottle because the 10lb. bottle did not have the high flow valve. When i made the change i had to cut the pickup line to the correct length and make a new angle on the pickup tube. If i did go with the 2 bottles how does that work? Do i run with both bottles open and just put a y fitting on the line? If one picks up air would the other one compensate for the other? Not sure of my options of this idea. Anyone done this or had the same problem i have?
Old Nov 26, 2007 | 01:29 AM
Bullitt4110's Avatar
If you run 2 bottles you run them both open with a Y, running 2 bottles does help with pressure loose. I am not sure on your pick-up problem, but seems to have the effect as when the bottle is low.
Old Nov 26, 2007 | 11:52 AM
TARZAN's Avatar
Sounds like you need to start checking for leaks before you do anything else...
-Will
Old Nov 26, 2007 | 02:40 PM
02' hawk's Avatar
I'm sure that it's not a leak. Did that already!
