main feed line
Old Nov 26, 2007 | 04:44 PM
firefighting1101's Avatar
Default main feed line
how many feet of main feed line do i need to run my kit from the spare tire well?
Old Nov 26, 2007 | 05:54 PM
2002RamAir's Avatar
Got mine there with 16...went throught the gromet on the pass side firewall and under the carpet into the wheel well...It was close with the 16feet but had just enough to make it work out!
Old Nov 26, 2007 | 07:33 PM
Nitro Dave's Nitrous Outlet's Avatar
It depends on where you are mounting the solenoids. The standard 16ft should be long enough.
Dave
Old Nov 27, 2007 | 12:20 AM
TARZAN's Avatar
As Dave said, it depends....16' should cut it, but if you're trying extra hard to hide everything, it all depends on where you're mounting your 'noids.
-Will
