Is anyone purging out of the two holes in the Camaro grill?
On each side of the word "Camaro" there is a hole and I was wondering if anyone has purged through it? What kind of setup did you use? (lines, etc.) Thanks
well... notta camaro but same basic concept
I just bought some copper tubing from sears hardware and several flair adapters (plus a pipe bender and pipe cutter). Then just bent the pipe to the shape needed and used a T connector (w/ends flared) to make it purge out both nostrils...
So w/a camaro you'd just run the line down from the purge solenoid following the radiator then T off behind the grill and have two L shapped lines out of that pointed out the grill
I think the lines were 5/16" OD... it was in a box all curled up.
Key is to bring the purge solenoid in and find a fitting that fits it, then just buy copper tube of that side and flare the ends of the tube
Don't you have to have your purge exiting a certain distance from the front of the car and the air intake? I thought this was in the rules for one of the national drag racing bodies for some reason... Anyone know for sure?
