98 pcm tach wire help
Old Jun 24, 2003 | 07:44 PM
JPJBC's Avatar
Default 98 pcm tach wire help
i did a search and i found a post that said the 98s tach wire is pin 35(white)...i looked at my pcm and the #34 wire is white and the #35 is green...can anybody tell me which one it is for sure...i need to hurry up and get this window switch installed. thanks
Old Jun 24, 2003 | 08:05 PM
Assassin's Avatar
Default Re: 98 pcm tach wire help
there are 2 number 35's check um both
Old Jun 25, 2003 | 10:20 AM
V-10 Killer's Avatar
I just did mine on my '98 TA. It's the #35 on the BLUE harness, it's a white wire.Anything newer, it's #10 on the other harness (also white).
Old Jun 25, 2003 | 03:16 PM
Tim 98z's Avatar
Just installed mine last week. It was a white wire. As your looking at your computer there are two harnesses. It's the top one and the right side bundle. Only white wire on there i could find with a quick glance. #35 sounds right but i dont remember the #.
Old Jun 25, 2003 | 04:13 PM
JPJBC's Avatar
awesome...really appreciate it fellas
Old Jun 26, 2003 | 04:46 PM
frcefed98's Avatar
I also have to thank Tim, I couldn't figure out why my N20 Kit wasn't turning on at 3000, I had the wrong white wire tapped Now it works just fine mUHHAAHHAAAAA.
9psi+35hp shot= Now time to get an A/F reading on the dyno to see how big I can go with the N2O shot.
Thanks a million, this board rules,
J
