wiring help pleaseee
i got a tnt f1 kit installed and i was driving and purged it and all of a sudden all my guages went out and so i pulled over turned the car of and it wouldnt start again. It turnes out that the morning fuse to the ecm was blown from purging....so i had that replaced at bumberas and they said that they disconected the wires to the switches below the center consal. Since i have not done any of the work ...when i look under there is it going to be self explanitory on which wires go where or am i going to have to know that. also do i need to change the fuse that the purge is on or something so it doesnt burn out agian.
most likly your going to have to know that unless you have diagram for the kit but since you didnt wire the kit up yourself you have no idea what they spliced into sounds like they spliced into power sources under the dash not the right way to do it when i wired mine up the whole system is on its own relay and fuses and power and grounds i wouldnt just up the purge fuse because theirs a reason its blowing you are pulling to much current through something and thats why its popping certant size fuses are their for a reason so you dont burn up the wirs and start a small fire that wouldnt be good
Best bet is to trace the wires from the point of origin, so you dn't get them confused....if you're lucky, the installers used multiple color wires, which will make it easier....
I'd just remove where the purge is hooked into a fuse, and run to the accessory on, under the hood, and fuse that line...
-Will
-Will
instructions for the kit is what i mean by diagram should be able to call and have them send you some if i knew how to scan stuff on to the computer i would post up a basic layout its preety simple to wire a kit might be able to do a search and even find it took me about half a day to do mine and thats with a bottle heater and window switch and i even soderd everything and took my time i was hopen some experts would chime in im still a rookie first kit iv had but if you have any more ? let me know
