Newbie Question? Dry Shot on C5?
Old Jun 27, 2003 | 01:03 AM
seefive's Avatar
Default Newbie Question? Dry Shot on C5?
I want to put a dry shot on my m6 98 C5. Every C5 ive seen runs wet. I want to put a 75 or 100 shot on it. I was told i need to put the nozzle before my MAF, which makes sense. Do i need a window switch, and is it even safe to run dry on my car. i dont think my fuel system will give out, especially when i rarely spray. Do i need a new fuel pump, or anything. i was going to run NGK tr55's but was told the NGK tr6's work much better, True? Thanks for any input.
Old Jun 27, 2003 | 08:21 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Default Re: Newbie Question? Dry Shot on C5?
Just because you will rarely spray, does not make it safe! If you are pretty much stock or have some bolt ons, your current 28# injectors should handle a 75hp shot. I would get a window switch and WOT switch. Both are not that expensive and are good safety measures. It would be bad to blow a motor that you would rarely spray because of the lack of $200 in safety equipment
Old Jun 27, 2003 | 05:18 PM
seefive's Avatar
i have a wot switch, and i guess i will pick up a window switch to be safe. is there any other safety equiptment i should buy? i will get the Z06 injectors when the fuel system needs it. Thanks.
Old Jun 28, 2003 | 01:55 AM
DONAIMIAN's Avatar
Ahh I see you finally joined LS1 tech eh.
Well with nitrous you only have to go lean once and thats your motor right there. I would also pick up a fuel preasure saftey switch. It dosent matter what injectors you get weather theyre the ones off a Z06 or not. Just go with a set of ford racing 36 pound injectors, theyre pretty much the norm around herer as a lot of people use em. For the fuel pump go talk to Chris over at speed demon saturday. Hes a pretty nice guy and could probably cut you a deal on a full fuel system too. Good luck
