O2 Sensor bung help
Old Dec 19, 2007 | 01:40 PM
dementia's Avatar
Default O2 Sensor bung help
Ok so I'm getting into the mood on working on my nitrous setup some more but had some questions about getting my wideband sensor hooked up. I've got a stock exhaust (catback but that doesnt matter). Whats my best option for getting the wideband sensor put in? From what I gather I can replace the stock one but that includes a ton of wiring right? Any write ups on that? Is there a way to just weld in another sensor bung or is the pipe before the cats all cast iron? I tried looking up pics of the stock exhaust pre cat but couldnt find good enough shots. Looks like its all cast though. Anyone?
Old Dec 19, 2007 | 01:49 PM
DopeFedZ's Avatar
What wideband are you using. They usually come with a bung to weld into your exhaust.
Old Dec 19, 2007 | 02:17 PM
dementia's Avatar
I'm running a plx wideband. It didnt come with a bung but thats not a prob. My friend runs a shop and he said he could spot me one and get it welded in but my concern again is whether or not theres a place to weld one into. They have to go before the cats right? Isnt it all cast iron before the cats? If so can you weld into that?
Old Dec 19, 2007 | 02:22 PM
ls1_doc's Avatar
No there is a good section before the cats to weld to. Only the actual manifold is cast. I took a step bit and ran it until the hole was the same size as my o2 bung then just welded the bung on. I did it right above the factory hole.
Old Dec 19, 2007 | 02:50 PM
Zero4488's Avatar
Restricted User
That would be the best way I would think...
Old Dec 20, 2007 | 12:05 AM
dementia's Avatar
Sweet thanks for the info I'll have to see if I can squeeze in there. The part that you're refering to, I take it its a section of pipe in between the cat and the exhaust manifold? Does it come off easily? If so I can just mark it off, unbolt it and have my friend weld in the bung. Is it that easy or is there something I should look out for? Also which side should I put the O2 Sensor on?
Old Dec 20, 2007 | 02:43 PM
ls1_doc's Avatar
that would work and put it on the same side as the factory one.
