What do you think of the specs on my 370/nitrous cam....
Old Dec 21, 2007 | 09:14 AM
slowprocess's Avatar
Default What do you think of the specs on my 370/nitrous cam....
I've currently been running this Comp 235/239 598/598 114 in my stock 6.0L/150 shot setup. I've purchased a forged internal 370 and will now be hitting it with a much larger shot(250-300) and was curious what you guys thought about that cam in this application. I'm also making the swap to a turbo 350 with a 3600 converter. The heads will be a lightly worked over angle milled set of 317s. I've been told this combo should make pretty good power, but I'd like to hear your opinions. Thanks
Old Dec 21, 2007 | 09:31 PM
Robert56's Avatar
That's no nitrous cam. A little more duration and lift on the exhaust side is what we need. Patrick G can spec ya a cam that'll work for your needs, he usually hangs in the motor sections.
Robert
Old Dec 21, 2007 | 10:41 PM
BOTTLEFEDLS1Z's Avatar
Robert
What he said. Your GONNA need more duration on the exhaust side. I have 8 degrees more duration on the exhaust side on my camshaft. Spraying anywhere from a 35-300+.....
Old Dec 22, 2007 | 08:16 AM
ATVracr's Avatar
My 370 cam is somewhere around 248/264 610/630 on a 115.
You need a bigger exh. lobe for sure.
Old Dec 25, 2007 | 11:35 AM
RAGENZ28's Avatar
My old n20 grind was 270/284 with a 114 lobe.
