would it hold up
Old Dec 23, 2007 | 09:08 AM
fuseone's Avatar
Default would it hold up
i wanted to know if the stock bottom end would hold up to a h/c/bolt on and say a 100 shot and if so how well would it hold up?
Old Dec 23, 2007 | 10:28 AM
Mike@HSW's Avatar
it would hold up just fine. lots of great shops in the area that can help you out with the install if you need it.
Old Dec 23, 2007 | 10:31 AM
jessedale98's Avatar
Hyjackkkkkkkkkkkkkkkkkkkkkkkk
I have 55lb injectors but new (stock) fuel pump. would it support a H/C plus a 100shot?
Old Dec 23, 2007 | 11:23 AM
fuseone's Avatar
ok thanks. just didnt know if the stock bottom end parts would hold that.
Old Dec 23, 2007 | 01:41 PM
jmill96Z's Avatar
It should handle it. If you had a 255 I would say no problems whatsoever. If you run a wet kit, just run a FPSS and you'll be fine.
Old Dec 23, 2007 | 08:04 PM
fuseone's Avatar
oh and this is on a ls1 engine just for more info if that would change any thing?
Old Dec 23, 2007 | 08:21 PM
ERIK@MASPORT's Avatar
Closed Sponsor Account
Yes Sir, check it out:
https://ls1tech.com/forums/showthrea...464&highlight=
